weili16888
Yes. I used the key open the door without electricity key buttons. Thank youFirst of all, can you get into the car @weili16888 ?
OK, good, why can't you open the bonnet?Yes. I used the key open the door without electricity key buttons. Thank you
I have tried push the start button but no any electronic sighYes. I used the key open the door without electricity key buttons. Thank you
If can open the bonnet. What can I do next?OK, good, why can't you open the bonnet?
Check the battery connections, check the battery voltage, check for blown fuses, check for any loose wires or connections.If can open the bonnet. What can I do next?
I once went to a dealer and they really ripped me off. So no more MG dealers for me.This is not normal behaviour, a battery should last much longer than that. You have to test the battery, a dealer can do this if you don't have the equipment. If the battery is ok you may have an electrical fault that is slowly draining the 12v battery.
