2023 mg hs sat nav
mvredhead
warsop
HS PHEV
hi every one ive had my new 2023 MG hs automatic excite cars wonderful only problem is i car get the sat nav to load bye half way thier is a dab wire that at the dealership hand over said you will have to come back for this to be taken out as the radio wound,nt work but that works fine so need a little help before contacting the dealership also how do you use the cruse control the weird position on the left hand stick usually on my old zafira touer was on the steering wheel far easy to get to just need some info many thanks
Hello
low arm is just one pull to you to switch on, take the car to the speed you need and press the end to set speed. To increase push up to decrease push down and release. Will move in 5 mph space.
