2025 HS Phev with multiple Issues
Paul S NI
Bangor Northern Ireland
HS PHEV
Hi There
I'm new to this forum and new to MG ownership. I recently took delivery of a pre registered HS PHEV Trophy and in the main am very happy with it except its now been in the dealer for nearly a week! There are a number of issues which all look software related. Has anybody else experienced these?
1. The front parking sensors do not trigger when you drive straight into a parking space or go to park close to an object in front of you. They only come on when you put the car into reverse??? Not much use when your drive in forward. 360 camera works looking forward but you would expect the sensors to operate and sound also.
2. The fuel gauge is wildly inaccurate. I filled the car up and it told me I had a fuel range of 895 miles on one tank! Great efficiency for £60 but obviously total rubbish. The gauge goes up and down sometimes showing 400+ , the next day 350 (despite the fact that I was running the car on battery only)
3. The Star * buttons on the steering wheel that you are supposed to be able to set to a number of different functions of your choosing will not store the function to the wheel.
4. The Blue tooth connection to my phone constantly asked for a new pairing code. Admittedly I installed a wire less connector into the USB A so as not to constantly have to plug the phone in to have Android Auto but it shouldn't require a new pair code constantly.
Any takers out there for this raft of issues?
The front parking sensors are as you find them - switch them on by going into reverse momentarily or via the screen. Bit of a pain but there you have it - they all do it this way so not actually a defect.
The 'fuel gauge' you talk of is an estimated range indicator (same as for the battery). It varies based on amount of fuel and recent driving 'style'. I haven't seen the figure you have but mine varies accordingly. I don't pay any attention to the blue horizontal line 'gauge', so couldn't tell you if that's more accurate regarding actual fuel quantity.
My 'star' buttons have always worked (car was new October 2024) but some later cars had another (later) software version, where the star buttons ceased to function.
My car goes in on Wednesday to, hopefully, have the latest software update that should restore the common (software?) issue where the car doesn't read road speed limits and the (connected to that) cruise control ceases to work. They did work fine, but I have a suspicion that the was an over the air update that killed them! My understanding is that the latest software restores those errors and the star button functionality to those that have lost it.
I can't comment on Bluetooth pairing - I plug my iPhone in for Apple Car Play and it works fine.
No doubt it's a pain not having your car but I'm surprised the dealer hasn't explained what's what. When you get it, I am sure you'll be delighted with it - I am with mine, despite the odd quirk and software issue, which most modern cars are afflicted with at some stage.
Hi Aerofurb
Thanks for your reply. It's good that I'm not the only one with these issues so it means MG should pull the stops to rectify them. Pity about the front sensors. Seems ridiculous that they don't trigger when approaching a stationary object to stop you from hit it. I might resort yo plugging in the phone. At present the dealer is struggling to get a software update into the car so it's a waiting game.
Hi Paul, item 1 as already mentioned is by design but still annoying, you can also swipe down the home screen to turn on sensors when parking forwards.
Likewise with Aerofurb, the petrol range varies wildly, seems to use current mpg to project a range but that's constantly changing, so I ignore it and use the app to see what % the tank has then extrapolate by my typical 40-45mpg. The battery though seems more steady and the 75 miles is so far looking pretty reliable (winter might be a different matter!). Mine too is a Oct/Nov 24 model and the * keys work fine (software version ends in R46), I believe R62 is available and the * key issue has been fixed so hopefully your dealer will apply that one.
Despite the niggles though I love the car, and hopefully you will too once you get it back.
Mine too has been in the garage twice. Software issues where the right hand display square freezes.
Air bag warning light fault coming through on my app. Emissions engine light fault.
The main one, and I still cant find out if this is normal. From the garage or MG UK.
When i accelerate in HEV up to 70 mph, level out and relax on the accelerator. The engine continues to scream away at 4000rpm. I have read up on how the engine works and it does turn on the engine intermittently to charge up the battery through a generator (series hybrid). But does anyone else's rev so high when cruising?
In the manual it states that to bed in the engine you shouldn't rev the engine above 3000rpm.
When i asked the dealer he stated that its not 1995 anymore and that info was rubbish.
As for the high revving, they ask me to see how it goes and hopefully in the future MG will find a cure for it??????? Yes i did have an angry face at the time.
Hi. Thanks for the info.
I understand the theory of how the engine is supposed to work.
The trouble is mine is over revving while not demanding an up hill acceleration or an overtake.
My battery is at 80%
I know the car has two gears. It seems to me for some reason after the car is warmed up it wants to stay in the lower gear.
I posted above in the wrong topic. I will move it there.
Moderator: Earlier post deleted, as there is now a copy in the other thread.
I appreciate this doesn't help if you are having issues setting up the * buttons but the demonstrator that I drove today had one of the * buttons set up to switch on the 360 camera. This quickly solves the issue when moving forwards.
My car also went in last week for not reading the speed limits / cruise control issue - six software updates later and it’s fine now !
If the sensors came on in normal forward motion, they would bleep at you every time you stopped behind somebody at traffic lights !
Someone posted that you can use one of the star buttons to turn on 360 and that’s a great idea.
I tried it on a star button for a while but I seem to recall, it still didn't bring the forward sensors on. I went back to regen selection on the left button and EV/HEV power source on the right - and snick it into reverse when I need the forward sensors when parking up against something
There seems no way to update the software as a driver only MG. Mine went in for the service light issue that came on after 1000 miles. They fixed that but now the * keys dont work when you set them. Same issue with the front parking sensors too.. They only come on when reversing or front camera is active...
