400.000km MG4 - 250.000 miles
jamakr4
Germany
MG4 (2022-2025)
Just came across this and I gotta say - I am impressed. I have no idea how you mange to put 400.000km on a car within just 3 years but somebody did it. Thats around 250.000 miles.
I sadly can't really understand what they are talking about but according to the comment section the soh of the battery is 80.43%. If the owner would have followed the German inspection and maintenance plan, he would have to go around every 2 months - Just insane! You can see the odometer at 2:36
This video takes you on a journey to inspect the condition of an MG4 electric car that has been heavily used for 406,203 kilometers in just 3 years. Mr. Don from Siam Chon EV garage performed a thorough check of key aspects of the car, including:
Battery Health (SOH): Checked via the BMS system, the battery health was found to be at 80.43%, which is considered very satisfactory for a car that has traveled 400,000 kilometers. The owner primarily uses DC charging. (18:02-20:42)
Suspension System: Wear and tear consistent with normal use was observed. Front rack ball joints, control arm bushings, and rear sway bar ball joints were replaced (the originals were plastic and loose). The total cost for replacing the entire suspension system, including labor, was approximately 15,245 baht. (24:12-32:54)
Cooling System and CCU: The cooling system (air conditioning) was operating at approximately 75% efficiency as it had never been cleaned. It was also recommended to extend the air conditioner drain pipe to prevent rust accumulation on the beam. The CCU box continued to function normally because the owner primarily used DC charging (13:08-17:17, 22:15-23:45).
Summary of value for money: The car owner considered this MG4 to be very worthwhile because the difference in fuel costs compared to using an electric car could be used to pay for the car installments. And even with very high mileage, the car still performed well and was maintained according to schedule without any minor problems (39:08-39:37).
    Votes: 1,099 77.8%
    Votes: 212 15.0%
    Votes: 103 7.3%
