A Cautionary Tale
SteveMSJ
Baildon UK, MG4 Trophy LR
MG4 (2022-2025)
A story as a warning to others.
We set off to the supermarket in our MG4 gliding smooth and quiet out of the drive as usual. Over the speed bumps by the school. No traffic at junctions so didn’t come to stop until we were queuing for the roundabout in the centre of our town, nearly 2 miles from home.
Heard frantic meowing from beneath us. Leaped out and peered under the car expecting to see some poor injured animal but nothing to be seen.
Then our cat jumped out beside the rear wheel, shot across the main road, dodging cars, through a passage and over a wall and disappeared. She must have climbed into the rear undertray and inadvertently hitched a lift into town.
We searched the maze of streets, shops and yards, but no chance of finding her.
The next day we posted notices in all the cafes and other notice boards but were not hopeful. Two days later, in the middle of the night, she popped in through the cat door completely soaked through but otherwise no worse for wear. I’ve no idea how she managed to navigate her way home but we were very pleased to have her back😁
You hear of animals climbing in to ICE car engine bays for warmth but obviously as soon as the engine is started they are out like a shot. The trouble with an EV is that by the time they panic you are moving at speed. At least she had the sense not to jump out until we came to a stop. It must have been a pretty frightening ride though, particularly over the speed bumps😱
If you look under the car behind the passenger side rear wheel you can see that there is just space for a cat to squeeze in by the motor/differential. You wouldn’t see the cat by just glancing under the car. I suspect she’ll never go in there again but I will be checking in future before driving off.
Don’t let an EV hater see this or it will be added to the list of reasons not to own one☹️
Glad you got her back safely!
Many years ago my mother set off from home and the cat was on the roof without her knowing. At the junction about half a mile from home she accelerated briskly (Golf GTI!) and the cat flew off the back of the roof and promptly disappeared into a hedge. Fortunately she also turned up no worse for wear.
my memories of cats and ICE are quite gruesome so i don't think this will ever be the case with EVs 🙏
I once managed to scoop up a low flying bird in a car with an unconventionally low and long front intake with a tray and a radiator mounted at 45 degrees. the bird didn't make it unfortunately.
That's a truly scary story. Particularly for me since, nine years ago, my cat vanished for two months and was finally traced living feral on a farm in the hills three miles away. I still bear the scars. He now wears this on his collar all the time, no exceptions.
The way your cat got home is quite well understood. Cats don't actually have a good sense of direction when out of their normal range. When lost they wander around more or less at random, but generally moving further out from the place they were lost in, until they find themselves in a place they recognise, from where they can find their way home. If they're too far to do this, or if they wander in the wrong direction, they may never get home unless you mount a search (as I did). Your cat was obviously resourceful and determined and lucky.
In my cat's case, he seems to have managed to cross a small river which he was unable to re-cross, although it wasn't much more than 100 yards from home. After some time trying to circle round and failing (there were sightings), he wandered away from the village, found a hunting range, and taught himself to hunt. It may be relevant that in his normal roamings (I discovered later) he frequented a couple of horse establishments, and the farm where he was found also bred ponies.
That is a rather sensitive subject.
Purrfect Catnav obviously 🧭
Thanks for the suggestion. I don’t know whether I can get her to wear a collar but it’s worth a try.
If nothing else I need a way of checking she is definitely not inside the belly of the car before setting off.
That's one of the things I've found most useful about the Tabcat - locating the damn beast when I need to know where he is. Is he in the living room when I'm about to shut the doors for the night? Is he just prowling in the garden or has he vanished somewhere? Quite often just getting that beep that tells you he's somewhere nearby is all you want - or conversely, not getting the beep reassuring you that he isn't somewhere you don't want him to be. Also comes in handy when staying with friends who have a large, slightly cluttered house, and he finds all sorts of hidey-holes to vanish into.
I've only found the actual cat with it once, when he got locked inside a neighbour's garage, but it was invaluable that time. I've had to go out and find the lost collar* more times than I can count, but heigh ho. I've got it down to a fine art now.
It provides such peace of mind. I know that I can locate him pretty quickly if I just need to know where he is, and if he does disappear I have the means to make an efficient search rather than wandering helplessly wondering if he's under any of the multitude of bushes around the place.
* evidence suggests that lost collar episodes strongly correlate with cat fights.
It was really rather tragic. I hit a pair of mallard ducks necking in a shallow dip in a long straight road at sunrise. The dip wasn't deep enough to conceal a vehicle, but it did conceal the ducks. I didn't see them until a nanosecond before I hit them at over 60 mph.
Hmm - duck à la grunge 😩
Coat on - off to Clydebank 🤩
I tried a collar and tracker on our previous female cat, but had to retrieve the collar from various gardens in the neighborhood on a weekly basis because of fights. We gave up in the end, but seeing her "patch" plotted on the map was interesting.
The current cat is male and gets in even more scraps (and associated escalating vets bills) and has a larger range (from reports of him sneaking in houses to steal other cars food) so I think a collar would be a nonstarter for him.
Bib probably better 🤣
You have to balance the safety release against the inconvenience of the collar coming off. A slightly tighter quick-release clip can make all the difference. So long as it comes off when a fair degree of force is applied it should be OK. I gave Jori a new collar late last year, and I've only had to go out and fetch it a couple of times since then.
Mmmm, something similar happened to me several years ago. I was driving a ford sierra at the time and a cat ran out in the road in front of me. I heard a terrible thud and looked in my rear view mirror but couldn't see the cat. I assumed it had run off, after driving a few miles the temperature gauge shot up and the car was overheating, it wasn't until I stopped and parked up that I saw that the cat had gone through the front grille and was embedded in the radiator. Very much dead! I am an animal lover and would never deliberately run over any animal. I was quite upset and had to get someone to remove the deceased cat. Didn't know who the cats owner was so couldn't get to tell them that their cat was dead
    Votes: 1,090 77.8%
    Votes: 209 14.9%
    Votes: 103 7.4%
