Today I did the run out to Heathrow and back to collect my daughter from the airport, and it was a totally different experience.
This time I did my charging on the inbound journey so we could have a straight run back without stopping. I went M5 and M4 to Reading and the Pod-Point charger at Lidl. It was 3.30 in the morning and as I anticipated I had the charger to myself. I arrived with 69% and plugged in the CCS and started charging via the Pod-Point app.
I then had a problem which underlined why I dislike using apps to charge an EV. Whilst I was sitting in the car having a hot drink from a flask, I had a text from ASDA mobile informing me that my automatic top up had failed and I had no credit left. I tried to manually top up the phone and it informed me that it had failed also. The car was up to 84% and started throttling, so the only way I could stop the charge was by hitting the emergency stop button, which worked and I was able to remove the CCS plug (I thought I might have a problem with that but it was fine).
I then had to revert to plan B as I was originally going to use the Source London fast chargers at Hounslow West car park. Without being able to access the website, it would be impossible to start a PAYG session. So, I headed for the small charging hub in Slough suggested by Striker as it was only 12 miles from my destination and would still alow me to make the return journey without stopping.
If anyone is travelling along the M4, this hub is only 1.5 miles from junction 6 and accepts contactless charging. I arrived with 77% charge and plugged into a 150kW charger, where I charged to 95%. At the hub there was a DPD van and another van plugged into the 7kW posts with no drivers, so I presume they had been left overnight.
I got to Hounslow West Underground Station car park with 86%. Weekday parking was £6.50 (a lot cheaper than Heathrow Short Stay). 2 stops on the Picadilly line and I was at Terminal 3. Picked up my daughter and back to Hounslow West. On to the M4, and no offence meant to any Londoners on this forum, but the lack of lane discipline and lack of indicators was frightening. Once we got past the M25 it was plain sailing and got home with 33% remaining. I subtracted the Sat-Nav distance from the GOM prediction and it said I would have 73 miles remaining. When I pulled onto the drive the GOM said 72. Not a bad guess once again.
What a difference it makes when chargers are available and working.
