QLeo
- May 17, 2023
- Scottish Highlands
- MG4
Goth Leo our SE LR has developed an odd issue which we're trying to narrow down at the moment. The issue suggests it's the dreaded CCU problem, but there's a chance it's our cable.
We've not had any issues in over 2 years with the car. It's the generation that can do 3-phase charging, and we often use the 22kW pillar in the village. In February, we successfully used a 7kW pillar overnight across in the east in Dornoch.
A couple of weeks back, I was back in Dornoch, and again had reason to overnight. We plugged the car in to the same pillars as in February. Everything looked hunky-dory but when I checked on the app an hour or so later, the charge had stopped. We tried 3 other plugs in that cluster, but all exhibited the same issue.
On our return, knowing the CCU issue, I plugged in to the 22kW pillar. It charged without a problem for nearly 2 hours, which was all the time I had.
Yesterday we were in Inverness, and after a DC charge (which has always worked, by the way) we'd done a bit of ferrying around, so thought we'd park at a 7kW pillar while we went for a walk to add a few more percent. Two pillars failed to connect. The third connected, but stopped after perhaps 2%.
So it looks as though whatever the problem is is restricted to 7kW and/or single phase charging. I guess the next step is to try a different cable, as it is possible, I suppose (clutches straw) that it's our cable.
I can't tell from reading some of the many threads on the CCU issue whether it is restricted to single phase/7kW operation, given that 3-phase charging seems to work. It looks as though this may be the case but I can't find an example of someone reporting this.
But I would appreciate any comments, on my logic or on my straw clutch.
