Cabansail
Lismore NSW Australia
Went for a bit of a trip today, up to Ipswich and back home.
Generally am liking the Xpower.
One thing did stand out though, the ACC is not as good as other systems I have used. A couple of times it suddenly decelerated due to a car approaching in the other lane. Then there is the drop in speed when cornering. In my old car I was used to 3 or 4 kph drop in a corner, if it was quite a change of angle. This seems to lose about 8-10kph on the same sort of bend. On the divided road following another car it works quite well.
Is this normal operation or is something wrong?
I think some of the UK owners have noted a change in the "drop speed in a corner" behaviour after some system updates, but I wouldn't be able to tell you the versions, and I'm pretty sure our Aussie cars are on their own software branch anyway. (although maybe not in case of the Xpower?)
I have a regular trophy bit the ACC whilst better than it was still struggles to deal with corners and overtaking vehicles. It also is a bit heavy in adjusting to attaching a slower vehicle. I tend to use it for short periods and switch back to manual control when it gets annoying. A minor disappointment
Since an update my ACC no longer slows down around corners that it used to. Otherwise it is still too rough to use when it gets busy. It slows down far to heavily, waits to speed up again then does that quite enthusiastically! I still use it on motorways if the traffic is light or flowing steadily but turn it off when it starts to get busier. I'd love it to be a bit smoother. I only ever use TJA in stop start traffic.
I find ACC handy around town as it helps me to stick to the speed limits. On motorways I compensate for the chunky speed adjustments by using the accelerator when/if I have to pull out to pass slower traffic. Again, using ACC on motorways helps me to maintain a sensible speed (no more than 70 MPH, honest officer!). For ages I was blaming LKA for making me wrestle with the steerting, until I realised that I'd held the button down and activated TJA. Once I learned how to tell the difference my world became a happier place
Well, ACC doesn't care if you approach a roundabout.... There's plenty of them here so no ACC in town.
Found the slowing in corners annoying at first and you just have to lightly press the go pedal to maintain speed. However, on dark wet nights I have found that knocking some mph off makes things safer in the bends
No to "old fashioned" cruise control.(n)
I can tell from using the adaptive version how often the cars in front of me speed up, slow down, speed up, slow down...
You would be constantly turning it back on again with the old fashioned version. With adaptive cruise control, I can obviously maintain a constant gap, no matter what the muppet ahead of me is doing.
I don't use it around the 'burbs though, only on free/highways.
Personally I want different combinations of features for different road conditions.
Easily switching speed control between, off, cruise and speed limiter, would be good. Switching radar speed control on/off, even for speed limiter mode would be good. And if TJA's lane control was accurate enough, then having that possible for all modes would be good too.
How you fit enough buttons on the steering wheel to control it all is a bit of a problem though 🤔.
And how much would you be prepared to pay for these riches? You'll not get owt for now't
Wouldn't it be nice if you could just have plain old fashioned cruise control?
My Mini Clubman let you switch between active and passive cruise. Always handy as the active was driven by camera only which couldn't handle certain lighting conditions (like low sun)
My last two Mazda 3's had Cruise Control in the older one and ACC in the later one. I think I only used the cruise control a couple of times in the older one but the newer one. It had the software very well sorted. It would drop less than 5kph in corners. The only option I would have liked in it was to stop it limiting the speed when going down hills. I would use it to get very good economy and set it at about 85kph when the limit was 100-110kph. So braking was just a waste of energy. I got good at turning it off and back on. The MG software is not as sophisticated (yet)
After thinking a little, not a lot! The features I would use are already present in the car, so in my mind it would take little extra to allow better control of them.
The MG4 is perfectly good enough, it's just it could be better.
They could use the star button system to cycle through the different options. Maybe not the most elegant solution but I would settle for that for sure.
Me too.
Others have suggested adding speed limiter options to the ACC/TJA long press button, which may also work.
Maybe add a 4th distance (or long press) to the radar arrow keys for radar off?
I'm not holding my breath for a retro fit to our models though 🙁.
Every one will have here different experience because of different software combinations (for exemple SC077 is only for FDR and EPS without FVCM).
I think that up do date softwares will have ok performance
    Votes: 1,049 77.8%
    Votes: 204 15.1%
