That's the oneLong press on the home button?
Thanks will try and report back.
Nope. Still the same message.That's the one
Thanks. I’ll sit tight for a few days.I had that a few days ago. It came back online several hours later. I did have to sign in again though.
I have Amazon Prime and logged in a couple of weeks ago. It’s worked fine since then.Quick question
Is this a paid account ?
I tried making a simple free account, and it said that it did not include Amazon music.
Was hoping they had some "Free, but you have to listen to advertisements" option
I click the yellow bar that says “log in” and then after 30 seconds of a white screen I get the error message as in post 1.
Edit: thought it was SOLVED!…Hi muppet,
If you still can't login the HU may need a reboot. I'm not sure.
I got the error page you mention on one occasion. It did sort itself out, I said after a couple of hours but it might have been overnight, can't remember exactly.
I got the impression, not sure why, that it was a car issue, not Amazon as I was able to login to Amazon Prime in the house no problem.
At the time, I did a search and Amazon say :
...in other words if 3 devices are trying to use the service, it will complain.
- Ensure that you’re not using the same account on multiple devices - you can only stream the same title to two devices at a time.
Hi I logged out only after it didn’t load a song up. I logged out of my phone account and then deleted the app.Hmmm as you say. It's good that you were able to get in this morning which tells us things do work. Could I ask why you logged out? I don't log out of my account in the car (or on my pc for that matter). It then loads with my AP account without further ado.
Are you auto-logged in to your AP account on your phone? The system may not like it if you also try to login in the car on the same device. Just throwing out ideas now.
Agreed - but one has a servant to attend to those thingsOK you need a 10 mm spanner and take off the negative - battery lead refit after 10mins
It seems to work on some of the bugs not all its one of them worth a try things
Don’t really want to mess with the battery myself! If it’s off tomorrow I’ll ring the garage. Thank you.OK you need a 10 mm spanner and take off the negative - battery lead refit after 10mins
I’ve just been logged out of my Trophy Connect Amazon Music and it won’t log back in. Any ideas?
