Any way to stop car from braking around corners?
CarbonEV
Manchester
MG4 XPOWER
The ACC starts to brake heavily whenever there is even a slight bend on the motorway which is really annoying!
Is there anyway to fix a speed and keep at that speed?
I understand if there’s a car up front and it slows down because of this but even the smallest of bends leads to the car braking.
The latest available update that changed increments from 5mph/kph to 1mph/kph also addressed the "slowing down in bends" issue ... you now need to have a much more pronounced steering angle for the car to start slowing down. I (mostly) like the way ACC works now. :)
The latest update reduces that significantly I'm told.
Mine only takes off 1-2 mph
That’s really good to hear !
I’m due a service in November so will make sure a software update is included ☺️
I have started using the same technique as Torryhun, just control the speed in the corner with the accelerator (I know it defeats the object of ACC) or turn off the ACC for winding roads.
Only time I can see it makes sense to decrease the speed in corners as much as some of the software versions do is when there are poor road conditions.
    Votes: 943 77.6%
    Votes: 180 14.8%
    Votes: 92 7.6%
