Anyone else been plagued by Airbag Warning messages?
Hi everyone,
There is another thread on this topic - not sure how to combine or whether that needs Admin help!
More importantly, I tried the "wiggle and press the contacts for the airbag" technique briefly described in the video on this thread.
Summary steps:
Go to CAR --> SAFETY menu and power off vehicle
Look under drivers seat for yellow cable connectors - check if it is too taught, coming loose, caught etc and push together firmly but very carefully
Power on vehicle and see if the airbag error clears
Apparently this is a problem for multiple vehicles although it does seem to be particularly bad in our MGs by the look of things.
I'll keep you posted but I did that and the error vanished straight away. Fingers are firmly crossed...
@crowe99, I feel like I owe you money! You just saved my a lot of trouble and possibly a chance my MG4 SE being detained at the dealership while waiting for an ECU replacement. Following your clear instructions here it took me about a minute to clear out the 3 months long nagging airbag fault. In my case it was the passenger seat. I remember that on the day I got the first error message, I had pushed the passenger seat all the way back and also flattened it, so I could use it as a workbench to reach behind the glove box where I was mounting an aftermarket amplifier. It all makes sense now. Flattening either driver or passenger seats and pushing them all the way back in a bed position probably put pressure on the airbag cable/ connector. I might have strained the airbag cable/connector with that seat position. Also, sharply moving the seat or road bumps also resulted in a fresh sms from the car to my phone about the same error. Clear sign of a partial loose connection.
It is fixed now and so easily..
Thank you
Thank you
Happy to help @gravity. Worth noting that since that post I did get the clip replaced by the dealer as apparently this is a known issue and if it keeps recurring that is the fix. I've had no instances since then but if it has sorted yours then you can avoid a dealer trip 👍😁
Hi, My MG4 standard purchased in June 2023, now over 30000km, and airbag anomaly every time I get in the car. Been at the dealer, who first wanted to put it through the computer, but then a mechanic said "no it's a known problem, we just need to order a clip"... waiting for the clip delivery and schedule for it to be fitted. This is in SW France!
It’s still with the dealer awaiting delivery of a new airbag - was told it’s one in the seat - been with the dealer since the beginning of March airbag not due til the end of April.
I think one of the problems is that the error code doesn’t seem to be getting logged properly (other than by the iSMART app but they don’t believe the app - ‘we done support the app’ is the phrase I kept getting). So when the car it turned off or the warning on the dash goes away the error code gone, it sounded like MG wouldn’t approve a repair without the codes so it’s a bit ‘chicken and egg’ and not very helpful.
The dealer eventually got the information MG needed from the car but it took a couple of weeks to get to that point and the work approved but the dealer tried to give the car back with the problem unresolved a few times when talking on the phone with them during that time.
If your driving with the fault it’s probably worth checking with your insurance that your actually covered as I’m pretty sure it would be an MOT failure if it came up during the test.
I can verify this is an MOT failure.
I had a similar issue last year. Yes, in general, one could say the cause was the clip but that will not be completely correct. You see the airbag cable, is fastened to a piece of the car body under the seat for neat cable management. Usually there should still be enough play to allow sliding the seat fully backwards for leg room. In my case the play was not sufficient, so it pulled against the socket/plug for the airbag connection point, right under the seat. This was the cause in my case. I told my dealer to adjust the cable play, so it stops pulling on the connector. He did this, and the error never returned. No clip was needed. I can however understand if your cable play was so short to, begin with, that the connector lock clip already snapped. Merely changing this without adjusting for cable length could spell a likely future repeat.
    Votes: 1,089 77.8%
    Votes: 209 14.9%
    Votes: 103 7.4%
