Macadoodle
- Oct 20, 2022
- Scottish Highlands
- MG4 (2022-2025)
One of the constant annoyances ( of many ) I find with the 4 is the stupidly keen to come on auto lights.
Only in blazing direct sunshine do they seem to stay off.
While waiting for a possible update to cure this sensitivity I discovered a pretty simple solution in the meantime.
The light sensor is in the middle of the dash under a little cover, use a plastic trim tool to gently pop it off and you'll see the actual sensor underneath.
Tried disconnecting it ( it just pulls out ) but as expected, the lights just turned on all the time then.
The cover is light permeable but dash coloured of course, so it clearly blocks a lot of the available light.
Went on a 25 mile journey with the cover removed and the lights did not come on at all
Usually I would be constantly turning off the lights passing under bridges, overhanging trees, fat people blocking the sun, you name it.
It's not particularly pretty, sure, but you cant really see it from the drivers seat. If there's no update to cure this tendency, I think I'll cut a square section from the cover and glue a small piece of Perspex from the back side to let the light through.
