ReintjeWA
- Oct 17, 2024
- Location
- Perth, Western Australia
- MG4
Yeah mine came with a little booklet too
I would say it's more like keeping your foot on the brakes. I'm very cautious with it and always have my foot hovering above the real brake just in case something happens.I also just noticed today when auto hold is enabled it keeps the brake lights on as if you had your foot on the brake.
I had assumed it was like enabling a hand brake where the lights would go out.
Auto hold applies the brakes using the same mechanism as when you put your foot on the brake. If you want the equivalent of the handbrake, pull the parking brake switch up or press the P on the drive mode rotary button. I'm guessing the brake lights go off in both cases but haven't checked.I also just noticed today when auto hold is enabled it keeps the brake lights on as if you had your foot on the brake.
I am happy with the way auto hold works it was just more an observation on how the lights worked different to how I thoughtAuto hold applies the brakes using the same mechanism as when you put your foot on the brake. If you want the equivalent of the handbrake, pull the parking brake switch up or press the P on the drive mode rotary button. I'm guessing the brake lights go off in both cases but haven't checked.
If you press P, you then have to select D again to pull away.
If you use the parking brake switch, the accelerator is still active and the parking brake is automatically released when you press it. As it takes 1/2 a second or so to release the parking brake, it will often pull away with quite a clonk if you use anything other than gentle acceleration. A very brief pause after the first touch of the accelerator allows you to pull away smoothly at any acceleration.
Where is the parking switch you can pull? I had this on my old 5 but not seen it on my 4 Trophy.At night I pull up the Parking Brake switch (not the rotary button) so the brake lights go off and the car stays in D. Pressing the accelerator will release the brake and the car will move off. So that is auto hold without the lights in effect.
It's next to the rotary select switch.Where is the parking switch you can pull? I had this on my old 5 but not seen it on my 4 Trophy.
lol I totally forgot that was there.It's next to the rotary select switch.
Certainly starts going, but with any luck it's a long slow process before it's gone.lol I totally forgot that was there.I could not even picture it in my head. Tell you what once you go over 50 your brain goes.
Just be careful you don't touch the brake before you want to move otherwise the auto-hold will release.I would say it's more like keeping your foot on the brakes. I'm very cautious with it and always have my foot hovering above the real brake just in case something happens.
54 this month and lucky I can remember my age and birthday lolCertainly starts going, but with any luck it's a long slow process before it's gone.
To be fair I have not once even touched it. Strange that it gets a physical button with pride of place when it seems to be useless.lol I totally forgot that was there.I could not even picture it in my head. Tell you what once you go over 50 your brain goes.
To be fair I did use the button on my MG5 FL (same position). More so because the Auto hold I found a bit annoying on that car. On the 4 I love the auto hold.To be fair I have not once even touched it. Strange that it gets a physical button with pride of place when it seems to be useless.
hardly even born!54 your only a Pup.![]()
My Ioniq PHEV had it but you first had to turn the feature on by pressing a button. So to start the car you had the Start button then Auto Hold then brake and into drive.I don't think I've had a car in the last couple of decades without this feature. Just press the brake pedal hard when at a stop and it holds the car when you release the pedal. It's for hill starts, mainly.
