backseat got a good soak!
jerrylooney
cork
looks like im accidentally hitting the button when I exit the car! Anybody else?
Hi. I take it your on about the window opening.
I had the rear NS window open for no apparent Reason. Only once upto now. Others have had the same. See this thread.
Interesting , I assumed it was just me being a bit careless when I get out.
windows should shut by code when you lock . simple fix if it is a sw bug or an ergonomic issue with klutzes.
Why should the windows close when you lock, many people will leave windows cracked open to prevent a car overheating during hot weather
Another thing to consider is leaving the wipers on auto when you leave the car, and it rains or snows before you get back in.
The wipers will wait until you're almost ready to close the door, and then sweep a load of snow or rainwater onto your lap.
I think i'm hitting the button accidentally as I get get up - not a deliberate action so easily coded out
How does the car know you've done it accidentally?
And not easy to code out that would take some quite complex decision logic to determine if you'd accidentally opened a window or not.
    Votes: 1,064 77.7%
    Votes: 208 15.2%
    Votes: 99 7.2%
