Battery balancing. No
How do other MGs handle it? Some EVs do it when they see an imbalance between cells, some do it on a schedule.
It appears its a tad trial and error, I managed my first Equalisation last week at the second attempt, details on my thread "Battery Equalisation/Balancing MGS5 second attempt"
But basically I used the iSmart app, I'm on Intelligent Octopus GO, so cheap energy between 11.30pm to 05.30am, I set it to start at 11.30pm and run for 12 hours, so the majority of the charge was carried out at off peak rate, I regularly monitored the last hour or so in several ways, through the iSmart app, on my Octopus Energy app and my solar inverter app, all of which gave a view of what was happening and the current being drawn, from the moment 100% was reached, the current draw gradually reduced over approx. 30 minutes to carry out the balancing or equalisation, which probably indicates it wasn't so far out of kilta anyway.
On our previous ZS EV in the charging section ( in the head unit ) under the settings for delayed charging times.
I do remember seeing a slide button, that when selected, it would allow the car to continue charging AFTER the selected off peak rate had ended.
Saved messing about with your normal off peak times I guess.
Just slide the button when you wanted to carry out a balance cycle, then flick it back when your done !.
Not sure if the S5 has this feature though 🤷🏻.
Yes it does, 'charge to set %' or something along those lines. Keeps going outside of time range 👍
It's in the battery page. That would keep it going 👍
Another thing, if you've only done 2000 miles, the battery doesn't need balancing so you won't see it.
I don't think this is true, I have seen it around 150 miles and 800 miles - the two times I have 100% charged. Charged to 100%, on the smart meter device it was showing charging at the full rate and when it got to 100% it went down to half that for ages and then stopped. That had to be balancing.
It's not a mileage thing, best practice is a once a month thing
