dsimpkins
- May 30, 2023
- Location
- Bristol UK SE LR MY22
- MG4 SE LR
Yesterday I needed to top up on a rapid charger to get home. I stopped at an Evyve charger, which is a brand I've not used before (mostly Instavolt or Osprey) Charging was fine, stuck about 30% charge in, and continued on my way. It used some of that charge getting home, and the displays updated as usual.
Wife used the car later on that evening, but only a very short journey. She said the car went up by 1% on that short journey and return. I said, probably the regen on a hill did that.
This morning going to work, the display on both the dash and infotainment showed no change to battery percentage. Odometer, and miles/kWh updated as usual. I got to work using ZERO battery according to the displays. This obviously wasn't correct as I know it uses 3 or 4% depending on traffic.
So, I charged it at work (I usually charge at work) Took battery all the way to 100% to ensure a balance charge took place, and on way home happy to report the battery percentage updated as it should ( I whooped out loud when it went from 100 to 99%)
Just wondering if anyone else encountered this problem? My theory is that the rapid charge meant the cells were out of balance, and the car's BMS couldn't report the battery percentage properly. A longer journey may have sorted it, but good to know a balance charge will fix it if it happens again.
