- Jun 9, 2022
- Location
- Bristol, UK
- MG4 Trophy LR
I know battery preconditioning has been discussed on other threads, but I've not seen the Zappi's preconditioning facility mentioned.
I know that you can't apparently select preconditioning from the iSmart app whilst the charger is plugged in.
However, the Zappi has a setting that you can set whereby after the car has signalled that the charge is complete and power is cut, the next time the car tries to draw power, i.e. in response to the battery heating timer setting on the app, then, and only then, will the Zappi provide a power boost to a set power value and then revert to normal charging parameters again to replenish power drawn from the battery.
Has anyone tried this? If not, I may just try it myself tonight.
