Battery SOH with Car Scanner Pro and Vgate dongle. Am I missing something?
JohnV6
Suffolk
I have seen various threads on this and bought car scanner pro & the vgate obdii as recommended. I have a ZS EV facelift long range.
With the correct profile selected I don't see the SOC , SOH, max cell voltage or min cell voltage in the dashboard .
However if I select them in "Live Data" they appear.
Any ideas how to get them onto the dashboard?
No need . I solved it. You can manually add readings to the boxes using the settings. So although the 1st screen showed the titles by manually adding the data came through
Did you manage to get each cell voltage or just maximum and minimum voltage please as have those but wanted to check if any cell was not balancing properly
I use an OBDLinlLX Bluetooth dongle with the android eZS app to get SOH. My battery has slowly declined over he last 30,000 miles (3 years) to 95.8%. The app only displays max and min cell voltages, they're never more than 20mV apart. 95% of charging has been done at home goodness knows if it has ever done a cell balance. I only charge to 80% at home until the day before a holiday or long trip when I go to 100%.
