Boot mesh questions
Maciej
Lincoln, Lincolnshire
I am waiting for my car sadly it doesn't look like it's going to happen this week so I can't check myself. In the boot on both sides you have those mesh organisers to keep your loose stuff from flying all over your boot. What are the exact dimensions of those. height width and depth if anyone knows by any chance or could measure that would be great. I want to know if the bag I have will fit in those.
They're not very high. On the Gen 1 the top of the mesh is level with the higher boot floor level (basically you can't see the mesh when the floor is set on the top level), I would assume it's the same on the new model, everything else in the boot is the same.
13cm at the outside edge, 21cm from the outside to the inner edge and 28 cm on the inside edge.
