Has the insurance company said they will spend time and money investigating the cause ?...
The car has been written off, we asked them to check for faults.
We'll have to wait to see what the insurance uncovers.
Yes.Can you confirm your car was a MK1
No no, all good, finding all suggestions extremely helpful!!!Sorry just trying to help from your 1st post I was thinking it was just a little love tap but now I see your car has been written off it was possible a bit insensitive
They have indicated they will investigate, yes.Has the insurance company said they will spend time and money investigating the cause ?
I just had a similar issue with a rental MG ZS. The car was parked in a slight slope. I turned the contact but not the engine (key not fully turned). I usually drive an automatic car, so when I released the hand brake, gear in neutral, and the car started to move, I thought I was an idiot and forgot to press the brake pedal. Then I did press the brake, but it had no effect. And yes, it was the brake, because I double checked by looking at it before the car crushed into the wall. My thinking process was not so fast as to pull the hand brake, though.Hi All, well we were loving our MG ZS EV, but we've had a low speed crash, and I tell you , the brakes didn't work! We'd already had some electronic weirdness: the console wasn't switching on, just stayed blank, and a couple of other electronic things went wrong, the lane warning system turned itself off and on while you're driving along. So we had it booked in for a service, but before that, while driving at a low speed in congestion 10mph, had to brake and just nothing happened. What about this automatic crash prevention mechanism?
What happened, I don't know, just slammed my foot on the brake and the thing just sailed forwards into the back of the car in front.
Has anyone else had this failure??
was this ZS EV or petrol? I can only imagine that the car was in neutral (not P) and brake servo was not on because the car was not "on" ...I just had a similar issue with a rental MG ZS. The car was parked in a slight slope. I turned the contact but not the engine (key not fully turned). I usually drive an automatic car, so when I released the hand brake, gear in neutral, and the car started to move, I thought I was an idiot and forgot to press the brake pedal. Then I did press the brake, but it had no effect. And yes, it was the brake, because I double checked by looking at it before the car crushed into the wall. My thinking process was not so fast as to pull the hand brake, though.
Er, the ZS EV doesn't have a contact to turn, no engine and no key to turn. I think you're on the wrong forum.I just had a similar issue with a rental MG ZS. The car was parked in a slight slope. I turned the contact but not the engine (key not fully turned). I usually drive an automatic car, so when I released the hand brake, gear in neutral, and the car started to move, I thought I was an idiot and forgot to press the brake pedal. Then I did press the brake, but it had no effect. And yes, it was the brake, because I double checked by looking at it before the car crushed into the wall. My thinking process was not so fast as to pull the hand brake, though.
It was petrol. The car was “on”, the display was on. Brake pedal should have worked.was this ZS EV or petrol? I can only imagine that the car was in neutral (not P) and brake servo was not on because the car was not "on" ...
That’s a bit surprising. The brakes should work with the hydraulic system regardless of whether the motor is on or off.not if the petrol engine is not working. on petrol cars, for brakes to work, petrol engine must be running.
if you turn the key half-way to contact only, display will be working but not the engine and not brakes.
On electric ZS, when display is on, everything works but on petrol only when the engine is In theory the brake must run with the hydraulic system regardless of whether the motor is on or off.
Yes s we've owned and MG z s hybrid for about four months now, and have been mostly satisfied with its performance features and economy. But I'm wondering if anyone has had trouble with it doing strange things like taking off when your foots firmly on the brake? The first time it was unusual but this second time has been serious and the car plowed into a tree. I know some will say your foot was probably on the accelerator but I can assure you it wasn't. Even if that was the case the emergency braking and the airbags should have come on because we did significant damage. We believe the car is a recall because of its age faulty safety features.Hi All, well we were loving our MG ZS EV, but we've had a low speed crash, and I tell you , the brakes didn't work! We'd already had some electronic weirdness: the console wasn't switching on, just stayed blank, and a couple of other electronic things went wrong, the lane warning system turned itself off and on while you're driving along. So we had it booked in for a service, but before that, while driving at a low speed in congestion 10mph, had to brake and just nothing happened. What about this automatic crash prevention mechanism?
