BYD 1000kW Chargers
Has anyone asked whether we actually want charging that fast ? This would actually slow down my stops as it would be so quick I'd have to wait with the car while it's charging and then move and park up to go and do the other stuff I stopped for. 🤷‍♂️
Dave B. has asked exactly that question...
The cable in the video looked like it was just thick enough for one conductor, and of course you need two very heavy conductors, plus the cooling. Ok, with cooling, the conductors can be a little thinner, but I'm sceptical.
I have come across all sorts as a spark. One of the situations was a shower on a 40A breaker fed with 2.5 mm² cable. I can't remember the shower size, but I had calculated the current at in excess of 45A. 2.5 is rated at 27A maximum.
But this shower had run for several years before conking out.
So could there be an element of overload built in to the cable calcs?
Edit.
Sorry, just realised...we're talking about DC here, aren't we?
Not sure there's much difference in a non inductive load, especially if you talk in RMS values.
That's what RMS is all about: making AC the same as DC from the point of view of heating etc.
There is a slight skin effect even at 50 Hz. But it's mostly about getting the heat out.
The calculations are based on continuous loads. Fuses, breakers, and the cables they protect can take considerable overloads for considerable periods of time, like the time it takes to have a shower. In the end, someone must have taken a longer shower than usual, or not enough time between showers, so that the hot cables could not recover.
I'm trying to work in something about the virtues of taking lightning showers, but it isn't working for me. ⚡🚿
I meant it in relation to BYD's calcs, not the shower circuit.
Oh, sorry. Yes, I guess that since a fill only takes 5 minutes, the cable won't immediately melt.
But it means that if you're the second or third BYD to fill up, you'll "only" get some 500 A. That's assuming that they derate the maximum charge current with cable temperature, as they obviously would have to.
But a 1000 kW charger would be quite expensive, so I think you'd want to be able to use it at near maximum capacity. But maybe you can share charging modules (located in the back end, not in the dispenser) with other, lower power chargers. Until everyone wants 1000 kW charges, that is... 🏎️
Edit: And the CCS2 socket for the next car won't be red hot like the first one. And the plug will have had tens of seconds to cool off with water flowing furiously behind the pins in the meantime. Reliability has to very low for a setup like this, however. Very hot parts will oxidise and wear more quickly.
Will they be able to modify the human urinary tract to allow for charge stop comfort with these silly fast chargers ?
