GranTurismoEra
In the UK there'll be cursing matches for those 5 minutes.But I suppose he'll only be hogging them for a few minutes.![]()
Dave B. has asked exactly that question...Has anyone asked whether we actually want charging that fast ? This would actually slow down my stops as it would be so quick I'd have to wait with the car while it's charging and then move and park up to go and do the other stuff I stopped for.![]()
Depends on the voltage, I've not seen any mention of what voltage their mega chargers are running at.Check the cable thickness, can that really deliver 1000kWs?
1,000-volt architecture apparently.Depends on the voltage, I've not seen any mention of what voltage their mega chargers are running at.
That's still 1,000 amps, a lot of current through that cable.1,000-volt architecture apparently.
That's what RMS is all about: making AC the same as DC from the point of view of heating etc.Not sure there's much difference in a non inductive load, especially if you talk in RMS values.
The calculations are based on continuous loads. Fuses, breakers, and the cables they protect can take considerable overloads for considerable periods of time, like the time it takes to have a shower. In the end, someone must have taken a longer shower than usual, or not enough time between showers, so that the hot cables could not recover.So could there be an element of overload built in to the cable calcs?
I meant it in relation to BYD's calcs, not the shower circuit.So could there be an element of overload built in to the cable calcs?
Oh, sorry. Yes, I guess that since a fill only takes 5 minutes, the cable won't immediately melt.I meant it in relation to BYD's calcs, not the shower circuit.
Will they be able to modify the human urinary tract to allow for charge stop comfort with these silly fast chargers ?Oh, sorry. Yes, I guess that since a fill only takes 5 minutes, the cable won't immediately melt.
But it means that if you're the second or third BYD to fill up, you'll "only" get some 500 A. That's assuming that they derate the maximum charge current with cable temperature, as they obviously would have to.
But a 1000 kW charger would be quite expensive, so I think you'd want to be able to use it at near maximum capacity. But maybe you can share charging modules (located in the back end, not in the dispenser) with other, lower power chargers. Until everyone wants 1000 kW charges, that is...
Edit: And the CCS2 socket for the next car won't be red hot like the first one. And the plug will have had tens of seconds to cool off with water flowing furiously behind the pins in the meantime. Reliability has to very low for a setup like this, however. Very hot parts will oxidise and wear more quickly.
