Benno
I am charging my ZS EV at home and the charging keeps stopping for no apparent reason. Does anyone else have this issue and potential solutions? Could it be related to the cold conditions (-5'C here right now...)
Need a bit more info.I am charging my ZS EV at home and the charging keeps stopping for no apparent reason. Does anyone else have this issue and potential solutions? Could it be related to the cold conditions (-5'C here right now...)
The charger I'm using is the 3pin plug one that comes with the car. I don't know what a CT clamp is or looks like but I don't have any additional connections to my knowledge..Is it a load balancing charger ie is there a CT clamp
Don't worry about CT with 3pin plug is it definitely stoping or just slowThe charger I'm using is the 3pin plug one that comes with the car. I don't know what a CT clamp is or looks like but I don't have any additional connections to my knowledge..
Strange one that. Assuming you have tried the good old disconnect everything, turn everything off, then reconnect everything (give the connector a good push into the car) and remember to lock the car?The charging stops and I have to restart it on my app. after about 5 minutes it stops charging..
The charger I'm using is the 3pin plug one that comes with the car. (I'm awaiting installation of my home charger)
No timer is set and the charge level is set to 80% (its currently at 55%) The charge is creeping up, i started at 40% this morning.
I'm plugged into the garage socket so no extension lead involved.Hi, are you on an extension cable or a new dedicated outside socket?
