Charging on ohme/octopus
That’s great detail and how I use my ohm and IO.
If it’s at 60% and I want it at 100 (it’s a short range SE so ok) I tell it to add 45%, better over than under.
Do you know what would happen if I asked it to add say 80% in those circumstances? I suspect it would just add 40% to get it 100%, do a bit of balancing, then cut out?
I.e. if you want to charge to 100% is it any problem to tell it to add far more percentage that it actually needs to?
That is just what I do with MG4, Ohme & IO. It is set to maximum charge in the off peak period and when it’s at 100% it stops.
Therefore. Not needing any attention from me apart from plugging it in when it needs a charge.
