Charging query
Gwynfor Hughes
Swansea
I have a Rolec charger.
I usually put the car on charge ( normally around 12.30am using Octopus night rate).
The car is only charging to around 118 miles.
Could you advise as to what may be the reason for this.
Many thanks,
Gwyn
Hi, I’m surprised that no one has responded to your post ? There are quite a few things to check and I do advise that if you are interested you look at posts on here about range and charging etc. Depending on driving style, outside temperature, accessories in use and other factors - you may only get around 100 to 120miles range. During the summer 140 to 160miles is around the norm. Octopus night rate runs for 4 hours so if you‘re setting your charge during this time you may not be fully charging your battery. Fully charged your battery should show around 455volts. There are quite a few other factors that can affect your range and if your battery will fully charge ?
Thank you so much for your reply. Since posting I have viewed other similar posts etc which has alleviated my concerns.
Cheers again.
