Charging question
MGMark
North East
Apologies in advance, this a really silly question I know but one I’m confused about.
I’m currently making use of a public charger; 22kw. The car next to me is charging at 11.3kw yet mine is only 2.7kw. Why is this please?
Could be a few different reasons, here are just some possibilities...
Current state of charge of your battery and where it is in the charge curve
The XPower has a max AC charge rate of 7kW if the car next to you has a max AC rate of 22kW then the charging station may have allocated the available power to allow for that
Some other quirk of the power allocation for the charging station (e.g. first car gets priority for power)
Temperature of your battery vs the other car (they pre conditioned you did not)
The Setting you have to limit AC charge rate may not be set to max
It will be charging at about 3.6kW for various reasons. The difference between the reported 2.7kW and the likely 3.6kW (0.9kW or 900W) is a combination of conversion loss (roughly 7% or 0.07 x 3.6 = 0.25kW = 250W), HVAC (heater or A/C), and 12V loads plus the DC-DC conversion loss. The other car was probably reporting AC power, the MG reports power into the traction battery.
So the important question is why you were charging at around 16A (3.6kW) instead of 30A (around 6.6kW). That could be the charging cable, if you were using your own. Can you see the cross sectional area written on your cable? For example, 2.5mm² indicates a maximum of 16A. I discuss this issue in some detail here, although in that case the on-board charger is three phase (around 10.5kW), where yours is presumably single phase (around 6.6kW):
I was using a tethered charger.
In that case, the EVSE must have throttled both of you to 16A. But the other car had a 3-phase on-board charger, and in the UK, your model only gets a single phase charger.
In some other markets, your model gets a 3-phase charger, in which case you would not have had charging envy 😉
If nothing else such as pool pump, washing machine, dish washer etc is running, I regularly see 7.0 sometimes 7.1 through the Wallbox app when charging.
Did the XPower in the UK ever come with 11kW 3-phase charging capability, like the early Trophy cars offered? If not, and the car has a single phase onboard charger, then that is only rated to 6.6kW.
That means the absolute maximum charge rate you'd see is 6.6kW, but with losses the maximum going into the car will be 6.4 or 6.5kW. (I have seen as high as 6.5kW in iSmart for my SE SR, and up to 7.2kW from my Wallbox app).
tl;dr ... 6.1-6.2kW in winter time is maybe not unexpected.
19.92 kWh in 2hrs 51mins, so an average of 6.9 kW and that's including power throttling due to the load balancer managing devices such as washing machine and pool pump cutting in during charging. Very happy with that.
