Charging the Battery
RTB
MK
ZS EV
Confused to say the least! I was trying to find out how to set the charge to 80% as recommended by MG for my ZS and this is what I came across while searching. My vehicle is standard range so is it okay to always charge to 100%
  • Battery Type: This feature might not appear if your car has an LFP (Lithium Iron Phosphate) battery, common in standard range models, as they don't need the same daily 80% limit as NMC batteries.
  • LFP batteries: For LFP, charging to 100% daily is generally fine and recommended for optimal balance.
If it's facelift ZS (from 2022 IIRC) then the standard range uses LFP battery chemistry which is good to charge to 100% with no negative longevity concerns.
Thank you for your message the vehicle is EV 2023 what's the llRC
