Hi mcishere. I assume you’ve already discussed this with your dealership, if so did they say they have knowledge of the software update PD052, and if they did whether it had been installed, it is supposed to be installed prior to delivery.
MG and the Dealerships appear to have a problem communicating, and we end up having to apply pressure to overcome this. Which you have already implemented.
As you’re aware there are seven pagers of discussion regarding the problem, and if you’ve read the posts you will be are aware that you are not alone.
MG will say it’s a characteristic of the model, and to be honest hybrids, all exhibited something like this, due to them relying on a mixture of engines, motors, batteries, and complicated software to provide an acceptable driving experience, and good performance/mpg. It’s a sort of trade off.
If push comes to shove, you have a month to reject the car due to it not preforming safely. The sale of goods act 2015/Ombudsman provide some help, but aren’t a panacea.
Good luck…..
Hi Noal
Yes I went to Dealership and asked about this update but they had no knowledge of update on till I referred them to this forum they then contacted MG UK which confirm there is indeed a update but will check to see if my car needs it. lol
email from MG uk
Thank you for contacting MG Motors UK.
I’m sorry for the experience you have had with the vehicle.
Please note that this concern has been highlighted to MG and is currently under review with the factory.The transmission operation of this model when travelling uphill is determined at this stage to be a characteristic of the vehicle that does not pose a safety or mechanical drivability issue, therefore, the vehicle can continue to be used. We are aware that customers have expressed concern over the annoyance of the transmission operation and therefore await feedback from the factory on whether a solution can be produced to improve driver enjoyment. MG will communicate with our dealership network should a driver improvement solution become available.
If you have any form of concerns with the vehicle, then I can only recommend contacting your local MG dealership so they can inspect your vehicle and provide confirmation on its drivability if required.
2nd email from MG uk after telling them it's unsafe losing power like this
Good afternoon,
If you believe the vehicle is unsafe to drive or is undrivable, I recommend contacting MG assist, The AA or your third-party breakdown provide.
They will be able to assist with getting your vehicle to a drivable standard or if they are unable to get the vehicle drivable, they will recover your vehicle to your local MG dealership.
If you are looking to return the vehicle, I recommend contacting the MG dealership you had purchased the vehicle from as they can confirm the options available for you.
if you have any form of concerns with the vehicle, then I can only recommend contacting your local MG dealership so they can inspect your vehicle and provide confirmation on its drivability if required.
I’m sorry this may not be the answer you had hoped for
