Connected but not recognised error - SORTED!!
Diggsy
UK
EDIT - all sorted, 10min negative terminal disconnect fixed things!
Assuming this is a MG assistance issue? Have had zero problems with the car until today…has only just had second service last week too - just my luck!!!
Noticed the 12v battery displaying 11.8v, and then the message ‘connected but not recognised’…no cable is connected.
Tried removing negative from battery but that’s not done anything aside from throw a million errors up!
Any other ideas before I have to make the call? Thankfully car is at home
Edit - no lights on charge port at all
Trying the negative disconnect again, for longer this time - didn’t give it 10mins last time. Will report back, although not hopeful…
Sorted!! Happy to report that the 10min disconnect has everything working again…phew!!
Is there a process now for resetting windows etc after a battery disconnect?
Fully open them and hold the switch in the open position for 10 seconds then do the same with them fully closed holding the switch in the closed position for 10 seconds.
You need to also turn the steering lock to lock a couple of times.
All the other warnings will clear after a drive.
Perfect, thank you! I’ll get that sorted this morning. Thankfully it charged overnight as normal, so I’m sure that has also boosted the 12v battery too.
Caught me totally by surprise to be honest, and as a result I’ll be keeping a 10mm extended socket in the boot just in case it ever happens again.
@Diggsy, did you have the low voltage battery charging system error. When my Trophy's 12V battery dropped to below 12V and this error showed I found I could not charge the car using AC or DC. In the end I connected a battery booster to the 12V battery and that 'kicked' the system into operation.
(Full details previously supplied.)
My wife had the car yesterday so I’m not sure how the error first manifested. I just saw it when in the car later and the first thing I spotted was the red 12V battery warning and it was sitting at about 11.8V. The error ‘connected but not recognised’ was present on the infotainment screen, but I’m not sure which came first if that makes sense.
All seems good today - 12V got a full charge when HV battery charged overnight, and I reset the steering and windows. Just need to take it for a drive to clear the other errors, but hopefully all is well.
Quick scan just now from the app shows 12.8V, which from memory is pretty normal.
Seems the same as my problem - low 12V battery voltage and failing to charge either the 12V battery or the HV battery. If the 12V battery booster had not worked my next move would have been to disconnect the negative terminal. Thus I avoided the resetting sequences. I've had no further issues since that time in November 2024.
Hopefully it’s a one off for me as well. Took for a quick drive earlier and all errors were gone - in fact they were gone when I got into the car, so must’ve cleared itself after I did the windows and steering wheel earlier. 12V sitting at 14.2V whilst driving which is back to how it was before this blip.
I have MG4 EV 2024 model (Dublin based) charged at home and public chargers .. zero issues. This weekend (Bank Holiday) tried public charger I've used before, would not connect or charge, charger said vehicle error, 200 kms from home on motorway (Tipperary). Some but very little alerts on dash, certainly none that remained visible on the dash to review or relate to MG Assist who I had to call, because there were zero options to refuel the car. Breakdown Assist declined to attempt a software review at the roadside. Dried all chargers before use, tried 6 different charger points at 3 different locations. All gave same message. This is day 4 without the car.
Got my car back to Dublin at an overall cost of €345. No car from 19/04/25 to 24/04/2025. I would not charge they didn't know why. Fixed issue - I asked reason for the issue was told 'software', but it's now been updated. On 09/05/2025 stopped charging at fast charger again, but will take a slow charge. June date for a 'service'. Dealership who sold me car are messaging me like I'm a dope hoping they'll intercede to speed things up as I had the car 11 weeks when this first started. I think I'm already done with EVs. But I also desperately need my car for work... SH1T SHOW is an understatement.
It also feels that no dealership wants ownership of the issue!!
That is really maddening. It's experiences like that that put people off EVs even though I don't think they're really any commoner than similar hassles with ICE cars. Did I see in another thread that the AA wouldn't get you home because you weren't 500 miles from home, when the T&Cs actually said 500 metres?
    Votes: 1,052 77.9%
    Votes: 204 15.1%
