retrobloke
If the key battery dies. Is there away to get back into the car. I was thinking of leaving a spare battery in the car.
How is the spare key inside fob used
Try it before you need to. I had to use the emergency key on my old Mondeo (suffered from phantom battery drain) and the first time I had to use pliars but after that it was free enough not to need them.You might need a pair of pliers as it may be stiff....as others have experienced...not handy if you are out and about
Thank you all for the advice. Completely forgot the iSMART
Have you just tried it to check s/w update didn't remove it or was that your previous test?I just tried it as a proof of concept ... I can't ever see me needing to use it in anger.
The function uses Bluetooth, so you'd need to have your phone already paired with the car.
