AJD10
Can anyone tell if it take longer to charger mg zs ev in cold weather. As I started to chargey car at 19:00hrs yesterday and I went to check this morning and it's wasn't fully charged. Thanks for any infor.
Your car will not pull more than 7kw from your home charger as the onboard charger in the car will limit it to around 6.65kw max as far as I am aware. My car did a charge last night, 3hr 54 min to take on 23.1kwh. I use a Wallbox Pulsar, Outside temp was -1cMine didn't seem any different at -3 deg C last week, it was still pulling over 7kW on my smart meter monitor.
I would have thought that if the car is only accepting 6.65kw then the output from your charger would be the same. I do notice my charger is always flickering between 6.60/6.65kw as the charger is working.I agree that the onboard AC converter limits the charge. I do see around + 7kw drain on my home system when charging though.
Range | 163 mi |
Rated Consumption | 295 Wh/mi |
Vehicle Consumption | 260 Wh/mi |
I know that, losses etc. and a computer and the telly on drawing half a kW.Your car will not pull more than 7kw from your home charger as the onboard charger in the car will limit it to around 6.65kw max as far as I am aware. My car did a charge last night, 3hr 54 min to take on 23.1kwh. I use a Wallbox Pulsar, Outside temp was -1c
