Downgrade wireless charger
mepa
Sheffield
I dont like things connected when not needed. So I decided to disconnect the wireless charger.
(on your own risk of course)
Really easy to do :
1) Pull out the R/N/D knob (yes just like that, with a bit force)
2) Pry the mid console along the edges (not the black part but in the middle of the grey part
3) then pull out the red tab to release the connector latch, and pull out the connector.
4) the connector is a 12V 5A fused via fuse F45, so you could have removed that one as well I guess, but that would disable the rear USB as well.
Hmm which reminds me that you can easily use that power and location for an additional GPS/LoRaWAN tracker, sound module to mimic motor noise, charging cradle for your Yaesu or whatever. 5A should be enough for any other gimmic. Not sure yet how the enable line works. It might report the charging working state to the body control module.
