Driver assist failures - only when it’s warm weather
r6steve
United Kingdom
Hi everyone - for about 12 months or so I’ve been experiencing multiple driver assist failures (ACC system currently unavailable, forward collision system currently unavailable, auto emergency braking system unavailable, driver drowsiness detection system fault) in my 2023 MG4 Trophy. The problem only happens when the weather is warm (15 degrees or higher and it’s sunny outside).
The warning messages come and go continually (every couple of minutes) while I’m driving and can be really distracting as each time they appear there are several warning “bongs”.
I took the car to my local dealer at the end of last summer and after a few attempts they diagnosed a fault with the “module” (they didn’t explain what it was called) on the windscreen behind the mirror and said they would order a warranty replacement. After a month or so I called them for a progress update only to find the service person had left the company and hadn’t written anything down :-( so the new staff couldn’t do anything without seeing the problem (the weather was colder and it didn’t do it again).
Fast forward to this week and the weather is warmer and it’s doing it again now. Apparently there is a 3 week wait for diagnostics when I took the car to them with the errors on screen but I’m told by the service manager that the technician has seen this before (I recorded a video of the messages) and thinks it telematics.
Has anyone seen this before? I looked up telematics and that seems to be the remote connectivity to the car and not related to the cameras/safety systems.
Anyone have any ideas what module this might be behind the rear view mirror? Blasting the aircon on cold at the windscreen for 10 minutes does make the warning go away so I do believe it’s the module behind the mirror causing the problem.
I really like the car but it’s really frustrating having to deal with the service departments when you have simple problems that take an age to diagnose/fix.
Any tips so I can make sure the service department diagnose the correct module would be appreciated.
Thanks,
Steve
I checked the battery terminals earlier today and was able to tighten both by a turn or two, however the error messages remained. I checked and the battery voltage remains about 14v even when these warnings are coming and going.
Anyone know the name of the module behind the rear view mirror? Or any other module that might be related to these driver assistance warnings?
Thanks,
Steve
Thanks for the advice, unfortunately towing mode doesn’t seem to silence the warnings. Tried turning off all the ADAS features too but warnings persist. Only thing that stops them is blasting the air con on fully power on very cold for about 10 mins when they all miraculously disappear. Hopefully the dealer will diagnose the correct issue when it goes in for diagnostics later this month.
Yes, could be a bad connection that the heat affects. It’s been driving me mad all week but despite repeated visits to the dealer they won’t do any diagnostics until the appointment in a couple of weeks time. I’ll report back what they find.
Quick update. Visit to the dealer today and they identified that it was a problem with the front view camera module. Apparently they have a few issues with these “overheating when being coded” according to the technician. He said my problem was a bit different but had the same outcome - stops working when it’s hot. A warranty request is being submitted to MG for replacement.
Do you mean the rearviewmirror?
Also Check my post.
He means the little tringle-shaped area of the front windscreen, which is behind that assembly that the rear-view mirror fixes to. That assembly isn't hermetically sealed to the windscreen so condensation could form in that area, and be slower to clear than the rest of the (exposed) windscreen. :)
Edit: that's actually what @Ian Key meant in your own thread. :)
    Votes: 1,081 77.8%
    Votes: 208 15.0%
    Votes: 102 7.3%
