Kithmo
Distinguished Member
I have a Prius as well as the ZS EV and you do need the Prius engine to run for heat and the demisting and/or defrosting takes anything up 20 minutes in the winter compared to 5 minutes with the MG.Most hybrids needs the engine to run for heat. So if your running short trips, you never use the electric when the weather is cold. Also you still have to pay road tax, congestion charge and some areas charge hybrids for residents permits, but exempt pure electric. Hybrids have higher servicing costs and more complex things break often. They are the great idea for that one or two journeys in a year, but for the rest of the year the hybrid's range would be wasted.
And if you really need the range for that once a year trip - hire a car, it would still be cheaper in the grand scheme of things and the once wise words from Jeremy Clarkson: "The fastest car is always a rental"
However The electric motor works just the same in cold or warm weather, it's just that the engine runs more to keep the car heated.
Mine is VED free as I got it in 2016 the year before they changed the rates.
The servicing costs at Toyota are well below many other makes and comparable the MG ZS EV.
They are not more complex than a normal ICE car as they have no gearbox, just a single planetary gear set between the engine and electric motor.
When I bought the MG last July, I kept the Prius for the odd longer trip to the coast but due to the present restrictions that turned out to be a mistake as it's hardly got used, only for local trips to keep it running.
I may decide to sell it when the insurance runs out end of March and go totally EV, then if a longer range ZS comes out later, I'll trade my current one for new or go for the MG5.
