first day with HS PHEV
Has anyone found that swiping the screen to the left to get to the settings is not quite as responsive, my ZS hybrid+ was very quick. Also noticing when approaching any obstacles from the front the warning sound isn't activating, but does when I put it into reverse to move away. Is there a setting for this that I need to activate?
From what I've experienced personally, and what I've read on here, that is par for the course on both counts. Front parking sensors only activate when reverse gear is selected, and touch screen response generally is a little laggy.
After 1500 miles I'm really enjoying driving this car now. It took a bit of getting used to but it feels good in the corners. Definitely think "Normal" steering mode is the way to go, and "Sport" mode for the throttle response.
My current most irritating feature is the indicator sound still is too intrusive. If that could be tuned down in tone it would be so much more pleasant.
I had a similar problem but because I turned the volumes to 2 (in settings) the indicator sound was reduced as well as the bings and bongs which was my intention. I turned it to max and that was too loud. Somewhere in the middle is about right for me; but you will get the right level for you by trial and error.
I didnt realise you can adjust those volumes.
It is kind of hidden
Swipe left
Select settings
On the rhs shows genera, Bluetooth, WLAN etc
Swipe up in that area to find volume settings
Alter vehicle information tone
Hope that helps.
Hi herandnu do you find driving in sport mode uses the battery up quicker or do you use it just as a quicker get away like for overtaking and from lights etc?
I only use it in hybrid mode at the moment. Also I don't tend to accelerate hard. I just feel the throttle is more responsive to small movements of the pedal in sport mode, which I prefer.
