Front suspension arms
whodafunk
Bradford
MG4 (2022-2025)
Why are parts so hard to find for the MG4.
I have a 2023 XPOWER and the front drivers side suspension arm (or lower control arm as they’re sometimes referred to) is failing.
Does anyone know where to source this part or any other MG4 parts for that matter?
I would replace the bushes but I also can’t find any of those, unless I go down the universal poly bushes route but I don’t know exact dimensions.
Mine's a Trophy so may well be different, but my dealer replaced some front suspension bushes under warranty at it's second service. I did have to wait for them to get them in stock. So if you can't find them anywhere else, hopefully dealers can supply the bushes you need for your Xpower.
I also have this problem. MG Bognor surprisingly couldn't find anything on 1st July but another MG garage correctly identified it Wednesday this week (noise and ride was getting worse OSF and NSF). Problem is MG haven't been able to deliver parts to dealership so I have a HS petrol for the weekend and hopefully get the Xpower back early next week.
Yes I had/have the issue. 75% of my driving is non-motorway so not been a major issue. Be nice if it has magically gone once I get the car back. Leave expires next May anyway.
Vibes are from the factory. My mate noticed mine the first drive.
Sorry got this the wrong way round, my car also had the vibes from new. I meant to say does the vibe issue contribute to premature failing of the suspension parts as these are the bits that were replaced in the single example of a working solution to the vibes from ilukey77
Could be connected. I'm sure a keyboard mechanic will let us know if completely wrong. Finally have car back and definitely feels better with bushes replaced under warranty.
Ah ok, I get you
I was wondering if the AEB has anything to do with these bushes failing being as it's so harsh when it comes on ?
Never had any of the vibrations thankfully.
I don’t think the automated safety braking would cause the bushes to fail, but it is annoying and excessive. I imagine the bushes are not the same quality as you would see on other cars. It’s probably the same for other suspension components that don’t have the required dampening quality and lead to premature failing of associated components. The MG XPOWER is a lot of car for the money and I guess they have to save that money somewhere.
……….., The MG XPOWER is a lot of car for the money and I guess they have to save that money somewhere.
I guess time will tell where that money has been saved as more & more parts wear out 😟. That’s three people above as I count it with similar problems … thankfully still under warranty.
