Fuel filler flap release wizardry...
Kenny14
Edinburgh
EHS
Hi, Is there a knack to getting the fuel filler flap to release? Yes, I've read the manual but every trip to the forecourt involves a random number of button presses which after a random amount of time (several minutes usually) the dash eventually displays the required message and the flap can be opened.
Many thanks.
HS PHEV EXCLUSIVE 2021
Many thanks.
1. Press the button with your thumb and hold for 2-3 seconds.
2. Release the button.
3. Wait for the message on screen that says you can open the flap.
4. Then walk around the car - and open the flap.
If you are new to this car, practice it a couple of times at home - before going to the pump. I did that a year ago.
Thanks. How long does it typically take for the message to appear?
I just double checked all this. Its like this ....
a) the press down is just 2-3 seconds. Then release the press down.
b) in a second the first message appears with a YELLOW fuel pump sign saying "please wait to refuel".
c) a second or two later the second message appears with a GREEN fuel pump sign saying "please refuel". It then gives you ample time to walk round the car to press the fuel flap door: no rush.
d) after you have filled and closed the fuel flap door it then waits about about 3-4 seconds before auto - locking the flap.
My car is 2023 MG HS + EV. I assume yours is the same, as there was no significant model change between 2021 and 2024. The new model 2025 has only just arrived into Australia.
