Vince31
- Aug 28, 2020
- Uk, Swindon
- MGS6
The user manual is little help on finding the fuse box. Im fitting a dash cam with a hardwire kit today so first things first find the cabin fuse box. Manual says it's behind the drivers knee panel, so after an hour of not trying to break anything I finally worked out how to get to it.
First thing is to prize off the end panel of the dash and remove it.
Then undo the two screws in yellow above holding the right hand side of the knee panel.
Then undo the two metal screws under the knee panel that holds the flat base panel with the footwell light in it (unplug the light). There are two more large plastic screws holding the panel corners to the front bulkhead.
Then starting at the left side of the knee panel start to pull the panel away from the dash, its just clipped in place. The fuse box is located RH side of the steering wheel.
