Granny Charger
colinc
Shrewsbury
HS PHEV
Can the Granny Charger be plugged in and left "live" all the time?
I have installed mine in a home-made mini-shed to keep it dry on the side of my house.
Works well, but I am fed up opening the door and lifting the lid on the weather-proof sockets in order to turn it on and off all the time.
Can I leave it switched on when not connected to the car?
I have left it on a few times and it hasn't suffered, so I assume it's OK>
I love the mini shed.
Could you mount something like this on the side
Why do they call it the Granny Charger I wonder ? Sounds disparaging to all of our Grannies to my mind ! I use my supplied charger plugged into the garage 13amp socket with a plug-in timer set for 8pm to 8am. I just plug the car in every night and unplug it from the car every morning. The socket is constantly set switched to live but the actual car plug will not be live all day. Oh, and full marks for the carpentry Colin !
I always though it was because in earlier model EVs you used it at grannnies house, when you visited.
I am of the same option.
Not directly related to the speed of the unit, although it is a little slower in its ability to provide a lot of energy, fast ?‍♂️.
Does anyone know what the flashing power and charge lights mean ? Usually they are solidly lit when charging , but mine ends up flashing intermittently.
I charged last evening but when I started the charge the green light started flashing. I ‘jiggled‘ all the connections after turning everything off. Switched power on again and solid green light! Guess there’s some degree of sensitivity built into the system demanding everything is 100% OK not just 99%!
Oh and flashing green light = not charging!
I charged last evening but when I started the charge the green light started flashing. I ‘chiggled‘ all the connections after turning everything off. Switched power on again and solid green light! Guess there’s some degree of sensitivity built into the system demanding everything is 100% OK not just 99%!
I would check your socket outlet for loose connections and general condition etc.
A good quality socket out is recommended for using a Granny unit.
They are pulling close to the rated load for a 13 Amp outlet !.
Thanks mate but it was the connector direct into the car that wasn’t seated firmly enough I think. Everything else was fine and house only a few years old!
Silly me , didn’t notice the Light Codes on the bottom of the charger - flashing Charge and Power lights = charge finished .
