Heater in the freezing weather
A/C takes moisture out of the air that’s why in auto it’s turned on heat only will mist up the windows.
Thank you! I tested it, and it absolutely works!
The drawback is that the energy consumption goes through the roof.
It does not use all that much, compared to if you had to only defrost it, using the "toaster". :)
