Yes it is to keep heating on etc, but it will obviously increase your charging times slightly, I did yesterday evening as I was cold.Sorry to resurrect this thread but......
The vehicle manual does contradict itself. At one point it states that the vehicle should not be ON when charging then elsewhere states to set the vehicle status to ON to check the rate of charge.
Is it possible to sit in the car with status READY when the vehicle is being charged at a rapid charger?
Many thanks.
Does the alarm arm when you lock the doors? Why do you need to arm the alarm to have the heater on?Hi all
I have done that with a/c @ heater on but you have to lock yourself in and sit still as you may set the alarm off.
My car charges on AC with the doors unlocked but I found the heater wasn’t particularly keen on warming up much.Hi all
Maybe due to the fact that the charger can't cope with or is prioritising charging the HV battery and running the heater. You're doing something it probably wasn't originally designed to do.My car charges on AC with the doors unlocked but I found the heater wasn’t particularly keen on warming up much.
I always rapid charge my eZS with the HVAC cooling on because of Costa Rica tropical weather.Sorry to resurrect this thread but......
Many thanks.
If you lock the doors from inside by the locking button on the door no, the alarm doesn’t set.Does the alarm arm when you lock the doors? Why do you need to arm the alarm to have the heater on?
Thanks.If you lock the doors from inside by the locking button on the door no, the alarm doesn’t set.
StrangeHi
Tried locking from inside but didn’t start the charge. Had to use the fob and it did. Then Alarm is on Automatically when you lock
Mine is the same as yourThat’s interesting. Mine charges with doors locked by pressing button on inside door while sitting in car. Alarm not activated by doing this.
