Help - No Charging on Granny Charger
Specimenno2
Coventry, UK
Hi all, I have a pre-facelift MG5 21 plate, I’ve owned the car for around 3 years, most of my charging through this time has been done via a granny charger plugged in through my window. For the last few days the car no longer charges on the granny charger, it locks, engages and then after 10 seconds drops off and says ‘connected - not charging’. I’ve tried a second granny charger and different sockets but still nothing. For a period today it was in a cycle where it would start charging, drop off, start charging, drop off but never for long. It works on a rapid charger up the road and I haven’t yet had time to try it on a fast charger. I’ve it booked into the garage in a few days for a separate issue (the heating has packed up) and will see if they can diagnose this too but wanted to see if anyone had any advice first!
Many thanks!
It's worth checking on a type2 EVSE before it goes in. Has anyone else tried their car on your granny EVSE?
wonder if the two problems are in some way linked
I wonder too. There could be intermittent electrical leakage from the heater to chassis, which might cause charging to stop. But I would have thought that if an electrical leakage was detected, the car would throw up a High Voltage Isolation fault, and not allow driving at all. Maybe the heater fault is somehow disturbing the battery voltage as seen by the Combined Charger unit (CCU, the on board charger).
But now that I think about it, it seems less likely.
Yeh I’m not sure if it’s linked or not, I guess it could be, but it drives fine and has no other error messages etc. everything else works, just no heating or AC charging!
Just wondering whether you have you tried disconnecting the 12V battery for a bit, reconnecting and test again?
Also, as @Jomarkh suggested, have you tried your vehicle on a different AC charger and tried your granny on another EV?
If the DC side works but the AC side doesn't (two granny leads, different 240V sockets), doesn't that point to an issue with the AC side of the charging port? Corrosion?
For the MG4 there are fuses for the CCU , charging plug, and the heater. I would imagine there are similar in the MG5 . The owners manual should tell you , but I am sure someone here would be more specific. Worth a look , if only to discount that possibility.
This ^ Because it starts then fails it's unlikely to be a fuse and corrosion in the charge port is not uncommon. It increases the resistance in the cable/s that can make the charge controller think there's a short somewhere.
I was told this was a problem with some very old DC chargers that were built when small batteries were the norm. A bigger battery has greater resistance and that made the charger go "computer says no.."
DC charging is using the AC signal connections of the charge port but completely bypasses the AC/DC section of the CCU.
I wouldn't rule out corrosion on the AC contacts completely, but the likelihood of an issue further downstream (CCU, EV-ECU) is far more likely.
As always with intermittent problems, I would do a HW reset first (12V disconnect)
