Is the Zappi reliable and compatable with your MG5 or are there some issues?When I got my MG5 SR I started with the supplied granny until I got an Ohme original, I then had solar installed so gotva Zappi. I have the Ohme still to get Intelligent Octopus at 7.5p for 6 hours overnight.
No issues with the Zappi or the Ohme.Is the Zappi reliable and compatable with your MG5 or are there some issues?
If you wasn't aware the EV.energy app works with the EO, there is an up to 5 minute delay (seems its a 5 minute poll). It may have features you prefer.Charging my pre-facelift with an EO Mini Pro 2.
It works, but the app is stupidly basic and there are much better chargers on the market these days.
Yeh I’m actually using it for agile, it mostly works but occasionally seems to have the wrong prices. Also occasionally the charger misses a checkin so it’s more than 5minutesIf you wasn't aware the EV.energy app works with the EO, there is an up to 5 minute delay (seems its a 5 minute poll). It may have features you prefer.
In my view it boils down to two wallboxes.What home chargers are people using to charge their MG5EV Trophy Long Range?
Doesn't have to be an Ohme Pro, I'm using a commando cable with IO and no problems at all.In my view it boils down to two wallboxes.
If you want to use Octopus Intelligent (the cheapest tariff by quite a way), you have to go with an Ohme Pro wallbox because MG isn't directly compatible with Octopus Intelligent but the wallbox is.
If you have or plan to get solar PV / Battery then MyEnergi Zappi is a strong contender, solar integration is brilliant but they havent finished the Octopus Intelligent integration yet, it is however in BETA testing I'm led to believe.
I would suggest you avoid wallboxes that rely on a connection back to a manufacturers server such as Hive and a few more, youre at their mercy and as many users have found out, if the manufacturer goes under, your wallbox stops working.
Still with an Ohme charger though?Doesn't have to be an Ohme Pro, I'm using a commando cable with IO and no problems at all.
Yes, just not the Pro model. I think any Ohme charger will work with IOStill with an Ohme charger though?
