Blair Douglas
How do you turn battery heater on mg 4 trougphy only had couple months still finding way about got warning temp to low
If you mean the cabin preheat, I cannot enable when plugged in after charge. I get an error on the app, happens every time if plugged in. If I go out, remove the charger and then select pre heat cabin it works. I havent tried pre heating the battery when plugged in, not manually via app anyway, I have that set at 06:15 every morning so I don’t do that manually.Question for the forum re preheat Interior/battery
Scheduled Charge set in car or charger
If you have the car on a scheduled charge (typically 00:30 to 04:30 cheap rate) post the scheduled charge but still plugged in, say 07:30, can you start either preheat using the app?
If yes does it override the schedule and take power from the charger or does it draw from the battery
If no what do you have to do to enable the function?
Secondly during the scheduled charge period does the scheduled battery heating work in tandem?
So the scheduled battery preheat works at 06:15 ok, drawing power from? Do you know?If you mean the cabin preheat, I cannot enable when plugged in after charge. I get an error on the app, happens every time if plugged in. If I go out, remove the charger and then select pre heat cabin it works. I havent tried pre heating the battery when plugged in, not manually via app anyway, I have that set at 06:15 every morning so I don’t do that manually.
Let me check that tomorrow morning, I’m plugging in tonight.So the scheduled battery preheat works at 06:15 ok, drawing power from? Do you know?
In that scenario can you schedule an interior/cabin preheat in the app or is that function not available?
Alan
It sounds like there's plenty of scope for improvement here, hopefully there'll be some app updates to make everything work more reliably.Let me check that tomorrow morning, I’m plugging in tonight.
Aware as in "we will fix it" or aware as in "it does that"?Confirmation, courtesy of siteguru, that MG are aware of preheating cabin not working when charger plug inserted in car but not charging. So it seems it will work off the battery with no cable inserted. Someone care to test for confirmation...no need to wait until morning
My cabin preheating via app works when not plugged in/charging, no issuesConfirmation, courtesy of siteguru, that MG are aware of preheating cabin not working when charger plug inserted in car but not charging. So it seems it will work off the battery with no cable inserted. Someone care to test for confirmation...no need to wait until morning
Just seen the message on the other thread. Thanks. That's good news, although they don't seem to be in any great hurry with improvements. But, when some manufacturers are just not fixing stuff at all, I think we should be pleased. The MG app has great potential.Aware as in aware and working on it....
I think this was the plugged-in-and-not-charging case. Unless you are saying yours works in this situation?My cabin preheating via app works when not plugged in/charging, no issues
