How to see current charging kwh?
andrewuk
Birmingham
How to see current charging kwh? the kia ev can see the current kwh when you are at public charging point.
It is quiet important to figure out. Because some 7kwh charge point onlu provide very low kwh like what I saw is 0.5kwh from kia ev. The the guy move to another 22kwh, it showed 10.5kwh, mich better than previous one
However, i can not find this information in my MG5... it only showed remaining time,Soc.....Ineed to know the currwnt kw information??????
Hi, i suppose you could look at the current been drawn on the 'electric information' screen just scroll through using the up/ down button.
all the key does not work on the whee while charging.
There is no current charging kwh information as you see in the attchment.
Not sure but if you put the car in ready mode to get this screen up
i tried, still can not find current charging kw information. the picture you attached has not the charging kw information.
You can test it if you can find the charging kw while charging.
Did you find a similar image?
If you multiply the V and the A you get Watts.
I did see this in another thread.
please refer to the attachment. so it is 369*8?
Just under 3kw are you on a granny charger?
well, it is a public charge pint of up to 22kw...it is free to charge so thaa nothing I can complain about it. The way of viewing the current charging kwh information is quite inconvenient. It should add the current charging kwh information to the charing infromation page so that I do not need to click the start button and a few off buttons to see and I also need to calculate by myself.....
