HS PHEV - Automatic boot not opening/closing properly.
Eponemuss
Stockport, UK
HS PHEV
So after 3 months of trouble-free motoring it seems I have the first glitch with my ‘new’ HS PHEV. When opening the boot this morning using the key fob I noticed that it did not fully open. I have it set to the highest setting. I loaded the boot and pushed the button on the car boot to close it. It descended by did not fully lock at the bottom. I had to push down on the boot to get the catch to engage. Have tried several times through various means to get the boot to open and close correctly but without success. Has anyone here had a similar issue? If yes, did you find a resolution? TIA
!!UPDATE!!
This was fixed by following the reset procedure laid out in the manual. Push the boot all the way up to the top, then close it manually. Open it again with the boot button or fob, and it appears to recalibrate. Very relieved.
!!UPDATE!!
And no more sore head from banging on the boot.
