HS Trophy PHEV Slow gear change x2
chilljohn
Notts
MG HS PHEV
Has anyone with a face lift phev trophy noticed the additional pause MG have introduced? it happens at 50 mph and seems to be a petrol gear box change this is followed up with the electric motor change at 55, or is it just mine ? i know they have changed the way it all works at it uses electric only a lot more than the prev one
hopefully there will be a fix .........?
just to be clear its an additional pause at 50 mph slight acceleration then another pause at 55 mph (this ine is the usual prefacelift one)
Had my car two years and it’s the gearbox quirk no fix nothing new there.
I believe the electric motor has two gears and it is this changing. If you look at the power gauge it goes down at the same time there is a pause.
Anyone confirm my thoughts?
It has 4 gears in EV and 6 in ICE it has some slow charging at certain speed and in EV you will find a power drop at 40mph if you are pushing it best to be easy on the acceleration.
