I created an AI with all the information on MG4
Hi Everyone,
Every time I had an issue with my MG4, I found myself spending more time searching through manuals than actually fixing the problem. That’s why I decided to train an AI, using all available MG4 manuals, to help with troubleshooting, maintenance, and programming. This AI can quickly provide answers and solutions, saving time and effort.
It can answer questions about:
  • Diagnosing issues
  • Disassembly and reassembly
  • Software adjustments
  • Problem-solving based on symptoms
The goal is to help each other without spending too much time searching through all the manuals.
To try it out, here is the link: MG4 Tech Assist
If you’re interested, let me know what you’d like it to help with. I'm open to all kinds of feedback, so feel free to share your thoughts and suggestions.
Edit: For the moment the chatbot is not well-trained on the MG4 XPower model. I'm working to train the model for Xpower.
That's really impressive; thanks for doing that. I thought of a reader that wants to suppress the indicator sound since it triggers a reaction in a family member. So I tried this; my prompts in italics:
Where does the indicator sound enter the main amplifier?
The indicator sound in the MG4 EV enters the main amplifier through the Body Control Module (BCM). When the turn signal is activated, the BCM identifies the switch status and generates an acoustic warning. This signal is then processed and played through the vehicle's speaker system via the entertainment mainframe.
Which wire is involved?
The indicator sound signal in the MG4 EV is transmitted from the Body Control Module (BCM) to the main amplifier via the vehicle's communication network. The relevant wiring includes:
  1. BCM to Amplifier Communication
    • The BCM transmits the signal via CAN Bus (High-Speed CAN Bus - HS CAN) and LIN Bus.
    • The indicator chime is then processed by the Front Infotainment Control Module (FICM) before reaching the amplifier.
  2. Relevant Wire and Connector Information
    • The harness Connector FC001 on the BCM includes communication lines that link to the infotainment system.
    • The BCM_LIN1 and BCM_LIN8 pins are used for LIN Bus communication, which can carry audio-related signals.
For a precise pinout diagram and wiring color codes, refer to the BCM wiring section in the MG4 circuit diagram manual or service manual.
I ask a question in English, bit the reply is in Italian
Just as an example. . .
Very very interesting, thanks for putting this together, I'll give it a look once I get my car and inevitably have some questions about it! Edit: any chance you could add the user manual into the training data?
Being AI though, you may want to double check the answer before snipping any wires :LOL:
I've fixed the language issue! The AI will now respond in the same language as the question, making it easier for everyone to use.
However, I’ve noticed that it’s not yet well-trained on the MG4 XPower model. I’ll be working on improving that in the coming days to ensure it provides accurate information.
Oh I don't know m8.
Bang on really with the answer afaic!
Not that MG will take any notice!!🤣
    Votes: 1,014 77.9%
    Votes: 191 14.7%
    Votes: 96 7.4%
