Incandescent bulbs!
YaR
Cambridge
MG4 Trophy LR
The interior bulbs for the front passengers are incandescent! Changing them to LEDs probably adds an extra few miles to range. I didn't think it was even legal to fit them to new products...
Sure, I've changed them to LEDs too, I'm just astonished that in this day and age any car manufacturer would use them. If not LEDs, then I would have thought halogens would be the alternative. It's very odd how the light in the boot, glove box, etc are LED but these weren't.
Has anyone swapped all the incandescent bulbs in the car? I take it that the rear lights are all old style.
I’ve read the MOT rules and the requirement for LEDs to be original fitment in a sealed unit applies to headlamps not indicators.
See section 4.1.4 for a definition of mandatory headlamps, and section 4.4 for requirement for indicators.
So indicators could technically be swapped for LEDs, except they will give CANBUS errors due to the reduced power draw and therefore they require a resistor in line with the light. Which is not a modification im keen on making at the moment.
You are correct that the MoT test currently will only look at headlamps, which I already said.
That doesn't mean that LED replacements for other exterior lights are legal - there is no provision for them in the regulations at the moment (only like for like replacements).
This has been a grey area for years and is unlikely to cause a practical problem, but worth noting that it could under some circumstances.
Indeed I wouldn’t fit the majority of led replacement bulbs purely based on the fact they most likely perform poorly.
Having said that, the Philips Ultinon Pro 3100 do comply with European regulations as they are the only ECE certified side indicators I can find.
Myself & several other have changed rear indicator bulbs for LEDs and have no CANBUS problems.
Each bulb uses 5W, I would say it would meters rather than miles to the range if you were to swap them for LED's ;)
Every little counts...
I agree, but it really is little in this example...
I thought I'd have a go at working out the extra range, I've tried to keep the numbers simple for this example:
Let's assume the MG4 does 6 KM per 1 KWh, which is equivelent to 6 meters per 1 Wh.
Let's also assume the pair of LED's use less power, lets say 4W instead of 10W
Let's assume for this example these lights are on for 1 minute per day
This means the incandescent bulbs will use a 6W for a minute: converting this to Wh we need to divide by 60 which gives us 0.1 Wh saved per day.
0.1 Wh will give us an extra 0.6 meters of range per day, or just less than 2 feet who prefer things in old measurements
Using the above example although I'm not sure about the calculations.
0.6 m x 365 days = 219 m per year or after 10 years 2.19 km / 1.36 miles
Well putting figures in the good old Excel spreadsheet........
Incandescent Bulbs 5w x 2 = 10w
LED Bulb x 2 1.44w = 2.88w
Saving = 7.12w
Assuming theyre on for 30 seconds on entry and 30 seconds on exit the saving is 7.12w per minute.
Using 4.5miles / kWh
7.12w / 1000w = 0.00712 miles or 11.45 metres.
Assuming a return journey 22.9 metres per day - 10 years 83.5Km / 51 miles.
Assuming you pay 30p kWh = £3.40
The LED's cost approx 50p each, therefore breakeven takes 2.94 years
My name is john and I'm a spreadsheetaholic :):):)
    Votes: 943 77.6%
    Votes: 180 14.8%
    Votes: 92 7.6%
