Rolfe
Moderator
- Apr 10, 2023
- West Linton, Scotland
- MG4
Thanks!
I hate to be pedantic, but it looks like you have the bulbs being on for 1 hour here, when it's actually on for a minute.Well putting figures in the good old Excel spreadsheet........
Incandescent Bulbs 5w x 2 = 10w
LED Bulb x 2 1.44w = 2.88w
Saving = 7.12w
Assuming theyre on for 30 seconds on entry and 30 seconds on exit the saving is 7.12w per minute.
Using 4.5miles / kWh
7.12w / 1000w = 0.00712 miles or 11.45 metres.
I can neither confirm or deny whether you are right or wrongI hate to be pedantic, but it looks like you have the bulbs being on for 1 hour here, when it's actually on for a minute.
7.12W for a minute is 0.1186666667Wh, or 0.0001186666667 kWh - please correct me if I'm wrong!
These say Quote "NO CANBus function ! ! ! It doesn't work on the new European cars & High-end Luxury with OBC wiring system. The onboard computer will reject them, or it will cause error, warning, or flicker."I got the warm version of these ones from a link somewhere else on here.
Amazon product ASIN B01LYEZPFC
You are right!I hate to be pedantic, but it looks like you have the bulbs being on for 1 hour here, when it's actually on for a minute.
Yes. I'm not using them on the indicator or brake lights, just the interior lights, so they're not using the CANbus system.Have yours been OK in the MG ?
All the so called canbus compatible led bulbs only have a resistor inside them to take the same load as an incandescent lamp.Yes. I'm not using them on the indicator or brake lights, just the interior lights, so they're not using the CANbus system.
I purchased the same ones and just fitted, like you I used two tools to remove the clear cover, I also unscrewed the two screws in the sun glasses holder and took the whole console down, made life much easier.Fitted these today and they look a lot brighter than the OEM's at 300 lumen each for sure ?
Amazon product ASIN B071LNH2D3
I found using two plastic trim tools was a lot easier - one to open a slight gap and then a wider one to get into the gap fully to lever the cover out ... it was quite tight !
